I question your mechanics diagnosis,..... I thought if an injector is fouled up, it plugs right up and stops fuel flow or seizes the injector open ??? You said you heard all of your injectors 'clicking' so they're not seized ,.. right ??? Two injectors "fouling" open at the exact same time, while both are still clicking, that just happen to be on the same coil ??? What are the odds of that ???
Did your mechanics or you test for spark on the two bad cylinders ???
I'm really quite inclined to suspect a bad wire feeding the coils,... a bad wire (or connection on it) can be intermittent.
I say test for spark to be sure.
