Stuck at the Gas Station
Mazda3_2004
2004 Mazda 3
I have an 04 Mazda 3 and it has been idling rough for a while and the check engine light is on...after im finished filling my gas tank, my car does not want to start..it sputters and stalls for a few minutes.....why is it doing this..???
Many auto parts stores can use their scanner and pull what the code is. I have read where not having the gas cap tight enough could cause an engine light to come on. Try doing a search for "cel" "gas cap"
Pulled this from another thread for a Mazda 5
The Mazda 5 is the 1st generation of the car, therefore it is going to have some issues, almost all first runs do. There was a guy I was chatting with at Tony March Mazda. we were waiting in the service department and he had 2004, and he had been into the service department at least once a week. The lattest issue was a faulty gas cap that was leading to a CEL and sputtering.
Also, after reading several reviews for the 5, it's basically a tall version of the 3 (same motor and platform, just heavier and taller).
hmm ya the guy i talked to said that nobody else would know what to look for on my car..the nearest mazda is 3 hours away...eek. he says i need to replace a part..but someone told me to disconnect my battery and reset the computer..would that fix it or is there something actually wrong with it.
You could try resetting the computer by disconnecting the neg batt terminal and pump the brakes a few times, wait 10 mins and reconnect. I believe the gas cap is related to not sealing correctly to maintain a proper pressure in the fuel system. The computer would not keep the cel on if the problem has been corrected (not cranked tight enough after one fill up).
Hmm well i called mazda in sherwood park and he knew exactly what was wrong, i have to take it in for him to look and make sure thats the problem, then most likely he will have to order a part and ill have to make another trip into the city on wednesday or thursday
cold lake
so I found out that there was a recall for my crash sensor..which is totally unrelated to the gas problem so they fixed that on saturday. but it turns out that i need a new fueld pump and some hose that has been recalled, but he didn't have those parts so he is ordering them today and I have to go back in on friday...
