moxnix said:Decided not to go down to 14's?
Cross drilled brake lines FTW!
HAHA!!!
It is probably too hard to find good 14s that won't cost a small fortune. Said small fortune could be invested in a Quaife!
Good to hear the P5 is still out and kicking butt. I miss the lift and drift of your car, Justin. Mine still isn't getting there, so I might tighten up the rear sway some. It is probably a combination of the courses I'm running (usually slow and tight), more rear camber, the spacers on the rear, and the fact I keep getting stuck with WAY over half a tank the past two events that keep the end planted.
