stock strut replacement?
jmv
2003 MSP #1475
My mom has a 3 hatchback, having weird rear suspension issues and I'm pretty sure that at least one of her rear struts is bad/leaking. If I wanted to replace with stock parts, are there any cheaper alternatives than the stealership?
The car only has struts up front, the rear uses normal skinny shocks. You could pick up some used ones with low miles from a forum member who upgrades to coilovers or yellows... even slightly used OEM MS3 rear shocks would work well as a replacement on a normal hatch.
Most any auto parts place should have replacement shocks. You may have to wait overnight but the cost would be less than dealer prices.
Clifton
