High Mileage CX-5 Owners Strut Replacement?
2015 Mazda 6 -- Skyactiv 2.5L NA W/ 91 Octane Tune
1. What mileage did your struts make it to?
2. What did you replace them with, and at what mileage?
3. Are you happy with the replacement performance and longevity?
Very interested in members' responses to this one.
Am likely looking at suspension work within the year. Have already done the LCAs and tie rod ends. Likely will do control links, anti-sway bar links and shocks during the next round.
Strongly considering the Koni Special Active shock product (8745-1346L and 8745-1346R fronts, and 8045-1347 rears), along with the Mazda upper strut mount bearings (B45A-34-38XA).
Back when I used to frequent the BMW forums, the general consensus was Bilstein > Koni.
Have you considered getting the entire quick strut assembly?
What's the mileage on your CX-5?
I have 311,xxx KM on my 6, and pretty much everything in the front axle has been changed except for the struts. My original struts are still in pretty decent shape. But, I purchased these for my car:
Based on the research I did, I would suggest either KYB or Bilstein.
2. What did you replace them with?
Last summer needed to do front struts, front lower control arms, and front sway bar links.
I replaced with OEM Mazda parts I ordered online (reused current springs).
So far been very happy with performance that was restored.
Put about 150km on my new KYB front struts so far.
Handling has been significantly restored. much faster and more precise turn in, no more wandering, corners at higher speeds, smoother.
I am pleased with the way these KYB struts are setup from the factory. They seem to prioritize higher speed stability and precision while loaded (with cargo or passengers,) normal for a larger sedan like the 6. But respond very quickly and eagerly at lower speeds as well. They are not broken in yet, still firm, but overall a tremendous upgrade worth every penny.
