** Stock rod versus Pauter rod **
Well accually the Kia Sportage used the BP series motors I believe. The internals I think are slightly different.
Kooldino said:
What are our stock pistons and rods made out of? Cast Iron?
Can't remember, but the FE3 (I think that's it) is good for 500HP on stock internals. Mazda Greatness!:D
TECHNICAL 5 said:
The (FE3) is also good for 500hp on stock internals,its found in the european 626.I want one!!!
This is what I was trying to say! Thank you very much!
I dunno about STOCK, but according to that guy's web page, HIS FE3 that he rebuilt from a Sportage block will hopefully handle 500hp.
perfworks said:
i didnt have an ounce scale
Go borrow the one your crack dealer uses.
:D
Hmm, so linux's rods and pistons are aluminum but they clang a bit...Why don't we get forged iron/steel/chromoly ones made so they're more streetable?
:D
well he said he lent it to you last and you gave it to some ho:p
the pistons for street /strip use that can handle higher cylinder pressures from F/I and the heat associated with it needs to be as lite as possible without sacraficing strength. that is what forged aluminum pistons from JE and many others provide.
Now is that a nice way to talk about your girl??? :D
Right, but forged steel wouldn't be any heavier than stock really, would they? They'd just be stronger...
It just seems like a good comprimise to me.
piston/rod weight
Doesnt this means that after installing the forged rods and pistons with more weight, the dampeners will suffer thus unbalancing the motor causing some kind of dammage on the long run?
Or it isnt that bad?
they are heavier. the best fot the money is Je . then hypereutectic alloys from KB. all depends on your budget and the quality you want out of a manufacturer
Re: piston/rod weight
this is why i said the engine needs to balanced if the rotational mass increases or decreases.
Damn those rods are beefed!!:eek: This current engine that was rebuilt was time limited and somewhat money limited. But I went with Hypereutectics and shotpeened the rods. And with the spare block I have now, I will prolly build that one forged some day:) But my previous motor was the #4 rod that nearly came out and thus cracked my piston in the process. So I will agree that our rods are limited in strength after boosting but tuning will be a key factor when going with the stock FS. Although forged is such a nice insurance policy.
Hey, any of you guys think about thermal coating any of the internals? I've heard that they can also help protect the engine greatly for high boost applications.
