BeNegative said:optima yellow is best w/ subs. expect 2 pay bux 4 it tho. (red is sufficient and a lil cheaper) a good ground kit and possibly a capacitor.
Maxx Mazda said:A cap is a no-brainer, but you can find Optima batteries really cheap at Costco.
BeNegative said:costco only has red here covered in dust. u can do w/o the cap but not wise if running all that power.
anarchistchiken said:Blue are for marine application arent they?
I'm running a 1500 watt setup and I can tell you, a cap is not neccesary. Lights dim like a b****, but lights dimming dont qualify a $200 expense to fix it imho.
As long as you dont let your battery die the stock ones will hold up pretty well too (I've had my system for about 6 months and the battery is still fine)
BiGx5MurF said:Sorry to thread jack, but a couple months ago, maybe like 10k miles ago. I stopped for a red, and my engine just shut off. It started up again quickly, and has never happened since. Anyone have any ideas why that may've happened?
toucci said:Was your A/C on? I had this issue once, but my idle wasn't very smooth. The solutiuon was to tighten the idle adjustment control screw to make it idle slightly higher, and reset the ECU so it would idle smoothly.
BiGx5MurF said:Come to think of it, I think the AC was on. Can you elaborate on this idle adjustment control screw?
When you say reset the ecu, do you just disconnect the battery, and reconnect it?
Maxx Mazda said:Don't worry about the idle adjustment screw. The shop manual tells where it is and how to adjust it, but it also states in bold letters "THE SCREW IS SET AT THE FACTORY AND DOES NOT NEED TO BE ADJUSTED EVER!" THat kinda thing, so don't worry about that.
toucci said:people have taken their cars to the dealerships for the stalling problem and they adjusted it. it's certainly the solution to this problem.
bigx5murf, the screw is located on the drivers side (intake side) of the throttle body, on the bottom towards the rear. you access it from the side of the car. use an 8mm wrench to loosen the locking nut and then a 4mm hex wrench to adjust it. turn clockwise to raise the idle, counterclockwise to lower it. I'd say give it a couple turns and see how the car idles when it's warm and not moving.
anarchistchiken said:Max, if it was never to be adjusted, then why would it be there at all?
