hi, over the last few days i noticed that something in side the car is squeaking, like if a spring wasn't oiled or something like that. i think it might be the seat. it gets kinda annoying at higher speeds. has anybody had a problem like that before?
Are you sure it's not the seatbelt buckle mechanism? Sprayed mine (at the bolt that secures it to the seat) with WD-40 and the sound hasn't come back in a year.
I have a slight seat squeak and I found that it's actually the side of the seat rubbing against the center console. I adjusted the seat height slightly and the problem went away.
i was just about to look up if there are any threads about this issue. mine just started a while ago. what to do about it?Next we will here about the dashboard squeak again.![]()
