A louie said:So now that I narrowed my choices down to 3, here is the next question:
Eibach Sportline, Pro-kit, or the Espelir? Which one? they are all stiffer then stock and have a decent drop, I just cant choose.
Recently purchased Tokico HPs & Tein H-Tech Springs. Hoping to install this weekend. If anyone cares, I e-mailed Tein and they said the H-tech drop for the Protege sedan was more like 1.4 front/1.1 rear. It makes sense to me because the Sedan and P5 use the same exact springs. So the listed drops should be more similar, like the S-Techs.
Btw, Tein marks the springs as "F" (front) & "R" (rear). I didn't see any other markings for driver side or passenger side...so I'm assuming that it doesn't matter. Can anyone verify this?
Left/right doesn't matter.
Do you mean that Tein lists the same springs for both the sedan and the P5? That's correct, but the oem springs are different for those models.
awsmp5 ran H-Techs on his P5, they only dropped the rear about 1/2" after settling. Here's the thread with install pics.
Have you got your suspension installed yet?
(pics)
Yes, I'll post before/after pics after they settle some. Now I'm just trying to work out the clunk. I detached both rear endlinks from the rear struts this morning and the clunk is gone. Debating on buying OEM replacements or adjustable endlinks.
Good quality springs, like your eibachs, will last longer than your car. Using stiffer aftermarket springs causes stock struts to wear prematurely.
so your saying that i don't need to get new springs? How can i tell if they are worn if that is the case cuz i my front left tire keeps bottoming out and hitting the fender. Your implying that this is indeed the strut that is causing the car to bottom out? Hmm hard to tell cuz someone was telling me it was the spring and not the strut..... This sucks i might as well just by new eibachs and struts......
Thanks for your input. any more feedback is appreciated
If you buy new eibachs, i'll take your old ones!!
Tylor
That's definitely true of MSP struts. Not so sure that's the case for the MP3.MP3 and MSP OEM Dampers are the CORE PROBLEM in the rear. They have raised the spring perch on those.
