Spool Front mount for the MSP
spoolinmp3
Contributor
Its pretty much verified that our kits fit the MSP with very minimal mods.
The kit includes A huge custom front mount PWR. Tab and bracket kit, Intercooler pipes, BOV flange, all clamps and hoses and ceramic coating (very sweet).
The onlypipe that will need to be modded is the turbo to I/C pipe. This will need to be slightly modded to work with the t25.
Basically an intercooler cools down the force fed intake charge from a turbo before it is introduced back into the intake manifold. The MSP has an intercooler but it is very inefficient, tiny and not mounted in a proper location to effectively cool down the air. Our intercooler kits will drop down your charge air to ambient temps. So if its 70 degrees outside your intake temps will be 70 degrees....
What does this all mean? Well to put it simply
Colder air is denser and will provide more power. You should see significant power gains at the same boost level.
And an intercooler will alow one to raise boost safley since the air is cooled down better preventing detonation.
Intercoolers provide more power, makes your car run safer and they look trick;)
one quick question...does the intercooler fit behind the grill, or do you need to take the grill off like in that picture?
No the intercooler will fit behind the grill. I just cut it out on my car for presentation purposes
cool, thanks!
No prob:D
how much?
We sell our kits for $900
Like I stated before one of the pipes will have to be slightly modded to mate to the t25 turbo on the MSP.
So one could purchase the whole kit for $900
Or we can delete one of the pipes and we can sell the setup for $800 dollars.
This will save one alot of frustration, You will have a hig quality intercooler, with all mounting brackets ect, fittings and hoses.
All right thanks a lot, any idea on how hard that is to do, i'm really new to turbo stuff
This is the pipe that needs to be moded....unless we can get some msp recruits in the miami area we can have a perfect bolt on kit.
This pipe can be easily moded by a muffler shop or welder for little time and money
Where the pipe curves up on the right hand side after the weld is where it needs to be modified to properly mate to the MSP turbo
Terry,
Thanks for the info and looking into it more after I called you today. I will definitly be willing to buy the kit (as soon as i get the loot together for it ) :D
Craig
(mspo)
somebody from FL get a move on and get down to their shop so they can finish this project. this is going to benefit all of us if that can be done. nice job on the front mount. unless you've got a shop around town with a mandrel bender or they know somebody who does its tough to get custom stuff like this done so a kit like this is the only way to go. nice job guys. lets see some shots from in front of the car more than 2ft away
':D
Wasn't there someone on here who lives near a Miami MSP? Get HIM!
anybody ever think of just remounting the the stock intercooler to the front mount position? i know mazda has good intentions but just don't cut it sometimes.
i know when i had my TII that IC would get heat soaked pretty quickly on hot days. for a stock IC it flowed pretty well with a decent design but Mazda picked just about the shittiest place to put it. right on top of the fire breather of an engine itself:confused: :wtf: so some people took it upon themselves to remove it and install it just like they would as if it were a big front mount, obviously much smaller but you get the point. hell, some even joined 2 of them together and made them one big unit.
