more T's = longer time for anything on the line to react. So if your wastegate is on the same line as two BOVs and a gauge, you will have more boost spike than if the wastegate is on a separate line. With the essential speed hardpipes, the wastegate is hooked into a nipple on the Turbo -> IC pipe, so the wastegate is immediate to respond to boost pressures. The downside is that boost at the manifold actually drops from stock because of pressure loss across the Intercooler - but that's no problem if you're using a boost controller.
The more direct you can get to the manifold for each thing that requires vacuum, the faster responding each thing will be. Figure out where you need the most performance (IMO wastegate is the most important, BOV/BPV second, and gauge third), and hook up your sources accordingly.
