Hi guys, i can't get the speedo working. I have a 2001 MazdaProtege with the 2003 MazdaSpeed Protege Engine and tranny. I machine a gear on the LSD, put the speedodrive sensor on it, plug the wire, but the speedo doesn't work. We test the speedo drive sensor on another protege and it work fine. So we guess it is the wiring in the car.
So I guess the wiring goes in the ECU ( I have the ProtegeSpeed ECU), and after goes in the cluster. They said i would have to buy something that will transform the signal between the speedo drive to the cluster.
The guys in the mazdaspeed section said you'll maybe know more about this.
Anyone ever heard about this? Or can give me more info?
Thx a lot for your help.
