Spark plug wire?
mazda03maniac
2003.5 mazdaspeed protege
Was wondering what type of spark plugs wire i should get? any suggestions? i was thinking about nology hotwires but i have heard bad things about them.
There have been numerous discussions on this topic and it's hard to say which is best way to do. You best be is to do a search, and you'll find a lot of info.
Hope that helps you.
NGK. You can get them from sparkplugs.com at a cheaper price than any other vendor associated with this forum. Search for part number ZE76.
You can beat their plug prices at partsamerica.com. I know as I bought my first set from sparkplugs and all the others from partsamerica.
Well, NGK are much better than the OEM replacement stuff you will get at AutoZone. You can go up a step to Nology or MSD wires, but it's overkill in my opinion. I have never had a problem with my wires, and I've had them for over 25000 miles.
all i noticed was better spark. in the high rpm area...in proved the flames coming out the exhaust too 1-1.5 foot flames.. they do need proper grounding or car willl runn like shyt...
You do realize that has ABSOLUTELY NOTHING TO DO WITH YOUR SPARK PLUGS. Sorry, I had to write that in all caps just to make my point. Flames coming out of your exhaust pipe is because you car is running too rich, and there is unburnt fuel making it into your exhaust system. That fuel then ignites in your exhaust system and sends flames out the tip.
so how come i did nuthing to the car except change wires same tune... how could i have triggerd more fuel to go threw my exhaust.? ever think the wires cause a hotter spark causing more heat to go threw.. to ignite the same amount of fuel that is going "into the exhaust"...
on i wasnt talking about my SPARKPLUGS..... SMART GUY..... if anything i went a step colder the following week to iriniums..
WHYS THAT?
well the nologys have a ground wire...
Nology HotWires are the most technologically advanced ignition wires available. HotWires create the most powerful spark possible. HotWires are engineered with a special built-in capacitor, exclusive only to HotWires. This revolutionary design allows energy from the ignition coil to accumulate in the capacitor until the voltage at the spark plug electrodes reaches the ionization point. At that split second point the entire power of the stored spark is discharged at once, creating a spark 300 times more powerful. The result is faster, more complete combustion, and most importantly,
MORE HORSEPOWER that's 100%. Smog Legal.
Well the way I see it, if the Hot Wres really are doing a better job you should have less fire or none coming out of your exhaust. The job of the spark plugs and wires is to burn the fuel in the combustion chamber, as we can tell they are not doing their job. That's lost HP you see coming out of your exhaust.
I'm not getting into a flame war about this, but you have no idea what you are talking about. One problem with these forums is you have ignorant people spouting information that they think is factual, when in fact, it is a load of crap. What exactly is "irinium"? Is that some brand spanking new element that's not in the periodic table?
WHERE DID YOU GET YOURS FROM
lets leave it at this you do your car and ill do mine.... he asked about wires i told him wat happen when i changed mine...
http://www.densoiridium.com/ << oh i guess we have an english teacher....
we will never have a complete combustion...
http://youtube.com/watch?v=0EMeQxImNmk
http://youtube.com/watch?v=Xp-EVOPBhIo
maby out of that you can make some sense. On how by improving spark you are getting a Hotter exhaust gas thus making it ignite more.. no one is saying my spark plugs make the flames come out....
