SPAL fan wiring help
tcrawford97
'03 Mazdaspeed Protege Spicy Orange
so I just purchased spal fans for my big turbo setup and want to find out if I can use the factory wiring harness to control them. they have a different plug type on them now but if I find replacements will the wiring for the factory fans control there functions?
please anyone who might have insight would help greatly
I don't want to cut the plugs off the factory fans in case I need them later or decide to sell them
Factory harness will control them fine, you will need pigtails from the stock fans if you are afraid of cutting your wiring.
You will need to make your own pigtails. You will have to source the stock connectors. Try a junk yard. As for wiring them, they will either push or pull depending on how you wire them.
