- '13 CWP MS3 & '16 Mazda6 GT
I think most of us are stuck there...seems to be the limit..
Prodigy said:he likes to be on top now.
It was a joke. Hangnail and I did his motor swap and a B18B is FAR from being a J-spec motor. It's a run of the mill Integra LS motor. I don't see how it is unfair to compare the FS-DE to even the lowly D series Honda motor. They are both economy car motors built for efficency. Even the B18C1 is just a GSR motor. Simply because there are worse motors built doesn't excuse mazda for making a somewhat below average vehicle. And no, i don't take any of it personal, hopefully people aren't reading my responses that way either.TurfBurn said:Comparing against Honda motors is not comparing against average. Honda motors are unique in the industry in a lot of ways... especially when you start getting into the J-Spec motors... so comparison against that is by no means fair or average. My point in listing that grouping was a fair number of those vehicles are very common, or a bit above average yet all have rather significant engine and build issues. The P5's don't suffer anywhere near those levels of issues, so I wouldn't be calling the P5 below average unless you plan to start saying those motors are all the bottom basement or something.
Replica said:It was a joke. Hangnail and I did his motor swap and a B18B is FAR from being a J-spec motor. It's a run of the mill Integra LS motor. I don't see how it is unfair to compare the FS-DE to even the lowly D series Honda motor. They are both economy car motors built for efficency. Even the B18C1 is just a GSR motor. Simply because there are worse motors built doesn't excuse mazda for making a somewhat below average vehicle. And no, i don't take any of it personal, hopefully people aren't reading my responses that way either.
build quality is build quality. i never hear about b18cs or 4v mod motors having problems like that. :shrug:TurfBurn said:I also don't believe that you can fault the FS-DE for oil starvation or a loose VICS screw. Somebody at Mazda should be shot for not loctiting those screws and using soft brass/steel instead of something else stronger.
HangNail said:b18b is not a "jspec" motor and the only real differences between usdm and jdm motors are slight changes in compression (jdm motors generally are a few points higher) and possibly mild fuel map changes. there should be no tangible difference in the reilability of a "jspec" motor over a "usspec" motor
HangNail said:build quality is build quality. i never hear about b18cs or 4v mod motors having problems like that. :shrug:
not that i know of but its possible. higher redlines would probably be because of different ecu programming rather than mechanical components (when comparing the same motor usdm vs jdm). but yeah with built motors just about the only thing thats still stock is the block, if you dont consider guards and sleeves.TurfBurn said:I thought some of them ran higher redlines... which would indicate some stronger components and revisions... I don't do honda's past my exposure through this racing buddy (who's motor I have to look at for him tonight.. having issue)... he is putting out 231 at the wheels N/A running 13:1 compression... his weight with driver and fuel is at 2200lbs now too.
youre right. it would be hard for a part to break if its not installed ... and the 4.6l ford is a relatively new motor. i believe they first started producing them around 94-95. i know they showed up in mustangs in 96, but i think they were in another car before that. the ls series chevy motors are relatively new also, showing up in corvettes around 95-96TurfBurn said:You also don't hear about it on the earlier Mazda's that didn't have the stupid VICS baffles...
But that was my point.. Honda motors are a rough comparison for any motor... I doubt you can find a motor company that produces motors with less problems than the Honda motors... maybe if you look at the 4.3L/5.7L and the 4.6L of chevy and Ford respectively... but the only reason for that is those blocks themselves have been in use for something stupid like 40 years.
I know his engine redlined at like 9500 rpm's from day one... so if that's a standard honda redline than who knows... but now with it fully built I think he can do like 10 or 11k or something stupid high.HangNail said:not that i know of but its possible. higher redlines would probably be because of different ecu programming rather than mechanical components (when comparing the same motor usdm vs jdm). but yeah with built motors just about the only thing thats still stock is the block, if you dont consider guards and sleeves.
TurfBurn said:Right... but again my point is the motor isn't at fault when it is a vics screw.. that is much more of an "accessory" failure that is killing the motor... it's like saying a timing belt that stretches and jumps teeth or breaks is the motor's fault.
Replica said:Wow, yesterday when i was leaving work, my AC would cut in and out on fan speeds 2 and 3. What the hell P5? It's like it knows i want to sell it....
see.. without the power of a positive thought and love of the car, the car senses that.. and gets upset...Replica said:Wow, yesterday when i was leaving work, my AC would cut in and out on fan speeds 2 and 3. What the hell P5? It's like it knows i want to sell it....
The B18C1, found in a GSR is pretty much the same as an LS motor and a CRV motor but with a different head and they also have oil squirters in the block. What makes Hondas so beefy is the bottom end has a huge girdle, or mains, or whatever youd like to call them. Even my D15B7 had a really nice girdle.TurfBurn said:I know his engine redlined at like 9500 rpm's from day one... so if that's a standard honda redline than who knows... but now with it fully built I think he can do like 10 or 11k or something stupid high.
vics is part of the motor. thats like saying just because my rod bolts have a tendancy to break doesnt make my motor unreliable. i have never heard of fasteners to be considered a wear and tear part on any motor made by any company. bolts are not under any circumstance supposed to back them selves out, SPECIALLY ones that are located in the intake that may be sucked into the motor.TurfBurn said:Right... but again my point is the motor isn't at fault when it is a vics screw.. that is much more of an "accessory" failure that is killing the motor... it's like saying a timing belt that stretches and jumps teeth or breaks is the motor's fault.
HangNail said:vics is part of the motor. thats like saying just because my rod bolts have a tendancy to break doesnt make my motor unreliable. i have never heard of fasteners to be considered a wear and tear part on any motor made by any company. bolts are not under any circumstance supposed to back them selves out, SPECIALLY ones that are located in the intake that may be sucked into the motor.
