 - Mazda protege5
Well I grabbed a door on the cheap off a white of 01 protege, luckily it had all the electric options so the wire loom plugged right it. It was missing about 4 or 5 little inserts so it's not the exact same. Be warned you need and extra set of hands and the door need to be wide open in order to get to the brackets in place and line up the bolts. Mine didn't quite line up, it looks pushed forward an 1/8 inch. I suspect my brackets are damaged and bent from the gaurd rail. I just pried the door and fender a bit and tugged on the door so it clears now. The electric motor thingy that controls the lock is shot so I have to manually lock it but I have a door again so no complaints. Plus I gutted my previous door for this reason. Needs a good bath and new trim (I'm probably gunna pull all the trim at some point) not sure how I feel about the shape of my paint at this point. I have mismatched yellow everywhere, a filthy white door, and small dings all over the car. I'm thinking about saving up to get the whole car repainted with the factory sunburst yellow and maybe getting all the dings filled, would I even be able to cover up that quarter panel and make it look smooth? I don't know, I need to research body work. Other than that new bulbs are on their way along with rear reman calipers, now I just need a passenger tail light.
