Single Runner Intake Manifold Installation
Hi, I recently purchased a protegegarage single runner intake manifold for my MSP and I'm not quite sure where which vacuum lines go where. I have emailed ProtegeGarage asking if they had some type of diagram or something since now the VCTS and VICS sensors will not have lines, but they don't have one. The car starts now, but dies as soon as it starts. I am assuming I have something hooked up wrong. Any pictures, diagrams, or information would be extremely helpful.
Thanks
i had the same problem with my when i tryed to install it. my car would rev to about 6000rpm the die so i put the old one back on because i could not figure out the problem. from what i have read it might be a vac line not hook out right but i never have figured out
All you do with the VTCS/VICS is plug them in. You do not have to connect them to vacuum lines. I always figured that the vacuum sources on the mani were all the same, for the more important ones (like the fuel line one, and one that goes to a sensor..) I connected those directly to the mani. The others you can T a couple going to one source if needed. Just find the vacuum lines that need a source, then find the sources on the mani, and connect them up. If your mani is causing weird stuff, it sometimes can be the sensors on the throttle body, a leak on the mani where it wasn't bolted down all the way, etc.
