Signature Layout
Equinox
Daddy Warbucks
Contributor
09 370Z Nismo
Now this is something weird. I made this signature, and at home it appeared perfect in a 1024x768 res. Perfect look is as attached.
Now it appeared this way at home, but then at work it appears messed up, I had to take out a couple 'br /' spacings in the code to keep the text from going beyond my sig and into other people's posts. Then I also had to re-align the middle table picture to line up with the outer table picture, to make it appear as one image.
Now that I fixed it at work (still 1024x768), apparently my friends tell me it looks messed up on their comps, (same res). What the hell. I used pixels as the unit of spacing, I don't know how it could change on a different computer at all, even in different resolution. What could be changing?..... or it it, hmm navigator at work and internet explorer at home?
Looks perfect for me... IE6
I'll have to check to see how it looks on Navigator.
YlowP5 said:
Looks good on Navigator too... Res. 1280x1024
okay I finished editing it, some people's opinions may have been off because I was midway editing it when you looked, lol.
Now it should look perfectly centered in Explorer, screw Navigator.
Just switched my Res. to 1024x768 and the "In The Works" section is below the box, but I'm not having any problems w/ alignment being off to the right like the last couple of posts. This was using Navigator BTW.
thanks, yeah I think I'm just going to have to accept navigator wont view it right. I know it wont view T3ase's sig correct either
