Serious Question
Pack434
Hi Everyone,
I recently had my Mazda 3 tires replaced and since then I have been hearing a noise from my front wheels when I make a turn. I wanted to know if anyone would know what possibly is causing this to occur? The noise occurs regardless of what speed I am at when making the turn.
Thanks for you help
what kind of noise? I am guessing it is just the new tread pattern of the tires. Get them rotated and see if it goes away. Also check your pressure
This happened to me when I replaced the OEM's with Yoko s.drives in the OEM size. Pretty sure it's just the more aggressive tread pattern, where the tread surface meets/creeps up the sidewall.
