I am getting ready to do Meguiars 3-Step system again. I emailed Mazda USA last year to verify the Vivid Yellow Protege5 has a clearcoat. They assured me that it does indeed have a clearcoat, but didnt tell me how the clearcoat is applied. I emailed Meguiar's about my experience with doing the 3-Step system last year. After doing step 1, I noticed some yellow paint on my applicator. I also noticed some yellow paint on my applicator when I did step 3. The paint only came off on various spots on the car. Below is the response I recieved from Meguiar's.
-----Original Message-----
From: Thomas "TJ" Harmon [mailto:THARMON@meguiars.com]
Sent: Monday, November 11, 2002 3:45 PM
To: 'spydermonkey'
Subject: RE: Paint problem?
The yellow that your are seeing is normal. This is usually an indication that your car was not clear coated or your clear coat is a tinted clear coat. Being that it was only noticed in some spots as well as just a little bit it sounds as though you may have a tinted clear coat. Seeing the pigment of your car on you applicator tells you that the products are working. You need not fear harming your paint and or clear coat.
Thank you,
T.J. Harmon
If this is indeed normal, what is the best way to prevent this from happening to much and damaging the paint job? Anyone else have this problem with their Vivid Yellow or any other color Protege? Any comments/suggestions will be appreciated. Thanks
To: 'spydermonkey'
Thank you,
T.J. Harmon
