Ok, let me get this off my chest, HOLY ****** s***!!!!! I start the thread, go to dinner and i have 3 pages waiting for me, thanks for stickin up for me and thanks for the opinions, i am dead serious about making this work, and it will.
i feel better now, few, ok, gt28rs' are too big, been talking to some people and twin stockers will work without any doubt, the twin inlet IC is a great idea but not too much room for the tubing, if you guys saw in my sig i already have a CS front mount with custom tubing, i will need a bigger intercooler of course, all the tubing will be reused, the hot pipes from the turbos will go two into one like a smooth bending Y tube then into the existing tubing, custom mani will be made alot tighter than the stock one, meaning the turbo's will sit closer to the motor and it will have dual exhaust run under either the motor or tranny with highflow cats or catless and light weight mufflers then will end somewhat in the middle under the car, as for intake, the 626 will work but looking forward to the CS mani, filtering will be ran the same way on both turbo's, just like the Injen CAI but on both sides, i will replace the windshield sprayer tank with a smaller tank and mount it somewhere else, the A/C will probably be removed and maybe the power steering too, will use a Miata alternator due to it not needing to run to the ECU, i'm still not a hundred percent sure if i wanna do 4 cylinders to 2 turbo's or 2 cyliders to 1 turbo split, still have to think that one thru, the motor will be forged, head will be ported polished and blue printed, new injectors and rail will be fitting but it runs rich as it is, standalone will be mandatory, i'm lookin at the Megasquirt, it's an excellent option, just waitng for our buddy to finish it up, my Apexi AVC-R has the boost by gear option and boost by RPM option, tranny and LSD comes with time, boost will be set appropriatly then work on the tranny wil start, either welded LSD or the Quief, tad expensive tho but it is sexy, replace the gears, flywheel, clutch.
Alot of work lies ahead, wish me luck, i WILL make this happen.
Thank you & Stay tuned
