twiztedjeckel
- '04 SVT Focus
yeah you have to watch out for the o-rings just as closely as you have to watch the blinker fluid level. careful careful
kep0ne said:i swapped my blinker fluid with some DOT-10 stuff from Redline fluids...gained 100 horsepower at the wheels!
:wtf:impo88 said:Would you people with no rotary knowledge just keep quiet. In reference to the O-rings he is talking about the coolant o-rings or seals. The lower intake manifold seals are prone to leaking because of the high heat area they are located in. The turbos sit no farther than about 4-5 inches from them and a lot of heat plus the already massive amount of heat from the manifold tends to increase their wear quicker than say a N/A. And as far as a 20b conversion goes. It wil only run you about 3k for a motor a around 3200 for the labor. 20b's are all that rare as many people think they are . They were in thousands upon thousands of cosmos built in japan
And what does that include???impo88 said:Corksport carries them for $3900 and their are a few others that are around $3200
impo88 said:I. And if you are going to be a troll like you are on the other forum than just stay off this one.
And who is going to install all of this??? Why would you want to get rid of the powersteering and A/C, doesn't that defeat the purpose???impo88 said:I was quoting basic costs for the motor not all the other parts needed and are we talking 2nd gen or 3rd gen swap here?. You dont need the A/c or the powersteering. $900 for a custom frount mount.$800 for radiator. Who is to say about the emissions if you live in an exempt state and im not an ecu brainiac so i would have to do some research. And yes it does include the stock twins possobility of ecu and harness( not always guaranteed) . And if you are going to be a troll like you are on the other forum than just stay off this one.
I would love to see you do it, and if I remember sinfest was banned was he not???impo88 said:I have alot of good connections on parts and such so yes REALISTICALLY i could do the swap for well under 10k. And posts counts can matter for crap . sinfestboy had a high post count and was still the biggest troll ever
