reverse works but also makes the noise and the other forward gears work fineSignal 2 said:How is reverse and the other forward gears. If just 5th gear is affected, I doubt it's the throw-out bearing. It may be your 5th gear synchro. At least in the early FDs, those were a little weak and if you missed a power shift into third and hit 5th, they would break. ??
Badgett said:reverse works but also makes the noise and the other forward gears work fine
