RSX wheels on MSP? (searched...)
chris1866
2003.5 Mazdaspeed Protege
Anyone know if the stock rims from an '02 RSX will fit on an MSP?
I believe they are the same bolt patttern (5x114.3) but that's it.
I have an opportunity to pick some of these up for cheap and was wondering if they would fit. They would be autocross wheels if it matters....
thanks in advance
I have used the S2000 wheels to autocross on. they were the front wheels which were 16x6.5 +55. FYI Our OEM wheels are 17x7+55. search to see exact dimensions of te RSX wheels.
Note, the S2000 wheel centerbore is bigger, so the RSX probably is too. You will need to pick up some centering rings
ok. the stock RSX wheels i am looking at are 16x6.5 bolt pattern is 5x114.3 and offset is +45.
On clubrsx, they have a thread about all the wheels that will fit the car, and for 17" rims they can fit up to +60mm offset. Therefore i guess our OEM racingharts would indeed fit an rsx, but i don't know about the other way around.
yeah those will fit fine. For autocrossing, I am running a set of 16x7 +43 wheels with 225/45-16 RS2 tires and the fit fine. You will probably need some hub centering rings though.
see mine here
