replaced deck.. now cluster doesnt work
okay well i installed my system/deck yesterday and in the process some of the deck wires came in contact.. now the cluster wont light up.. the door open lights up along all the other small things.. but the speedometer, or the rpm etc.. also where the heat is doesnt light up..
anyone know what could be the problem? ive checked the fuses
Recheck all the fuses. i can't remember off hand the name maybe courtesy light fuse and even though it may look good there maybe a hairline gap. If have a test light(AIRBAG SAFE) or multimeter make sure 12v runs on both sides...turn igntion on when testing voltage and you did check both fuse boxes 1st one insde driver's kick 2nd inside engine bay on driver's side infornt of battery. good luck my friend.
bump... i cant figure this out :\ ive checked the fuses.. ive checked the bulbs
edit: another thing to add.. when the wires were hanging out before i unpluged the battery when some of the wires touched the dash lite up when the lights were not on and when i turned the lights on then turned off.. now it just doesnt work period. (freak)
check your accessory wire on the back of the radio. If that wire touched ground then you shorted out your main fuse (the big amp ones), run a circuit tester to all the fuses and it will tell you if its live or not
