Remote Starter Recommendations
edboc
2010 CX-9 Grand Touring & 1999 Miata 10AE
Does anyone have remote starter recommendations? Does it matter if I have the keyless card or not, or are all remote starters compatible with any car?
The factory remote start is a separate fob, and if you have advanced keyless or not, still have the same remote start fob, so that part does not matter. I don't know a good brand, but can offer this tid bit of advice: The cheap kits at walmart, target, etc, have a high failure and/or fire rate (yes they catch fire), would not recommend these.
I'm thinking of getting a viper remote start.
I have the instructions for installing the oem remote start. This could be helpful for the installer since it has the wiring diagram. If going aftermarket I would recommend getting the oem remote start harness to make it more plug n play and easier for the installer. I'll scan the instructions when I get a access to a scanner.
We had the factory remote start installed when we got the car (and they forgot to add it to the final price ;))
