I was hoping to order the RB cat back for my P5 soon.
Only problem is:
I am not too sure what the tip will look like. I found multiple pictures on the forum that look different. Some have the "double tip" that is similar to the stock tip - essentially a thin metal pipe with the thicker RB tip wrapped around it. Others do not have this thin tip and only have the RB tip - a much cleaner look that is much more after-market looking.
Here are the pictures i am referring to:
What should I expect the tip to look like? If it comes with that inner metal pipe, is it possible to remove it so I just have the outer pipe for a cleaner look?
Thanks!
Only problem is:
Thanks!
