rar40941's build thread
U can see the mad poke I had
that was at what offset width and camber? im going to be fitting a pretty aggressive set soon, let me know.
Offset was at +25 and width I'd 9.75 offset and camber was 2.3 or 3 that was stock camber on my coilovers u might beable to slot like a mm and go little more but not much room with the strut
I think I had 8 to 5 mm's of clearance from the strut no spacers no slotting of any cind just used the stick slotted canber with the coils. Civickilla if I was u get the get the k spot camber plates in the rear they are only 200 dollars and they bolt right up to ur coils and add 1.5% of camber and if need be u cam slot like a mm or 2
i can get 2 degrees from direct slotting, camber plates wont help me much, in respect to how much i would have to pay for them. and fyi....dont measure camber in percent lol
but thanks, just the info i needed
Alright man. U got a piont there u can just get away with slotting man and good luck on fitting the new wheels man
Was it hard to fit your scooby lip
basically just trim the upper portion off to make it sit flush, use a heat gun to get any unwanted kinks out, line it up with your bumper, and use a bunch of self tapping screws to secure it to the bumper
Ok got my v brace it's reps old on and now I have to strip the hole thing and re paint it so tomorrow is going to be a long day :-|
Similar Threads and Articles
