dirtysouth_msp said:Well, a vac leak or leak in the intake track after the MAF can definitely cause a lean condition. It would kinda suck if you paid for new injectors and there was a leak the whole time causing the lean condition.
Since you say that you were only seeing about 10 in Hg of vac at idle, I would bet that it is a vac leak rather than a leak in the intake track.
EDIT: What mods do you have that are causing you to so desperately need your Unichip tuned?
honestly you shouldnt need those injectors yet, but if you want to go higher then I would suggest them for sure, at this level you will just be dumping fuel. I am similar to Rob but no unichip, a couple extra goodies he doesnt have though.(enguard)zzMSP03.5 said:Ok spoke with them today, there was no leak my gauge was bad so i am going to have to buy a new gauge, he said its off by 6psi and when you shut of the car it stays at around 5-7psi.
My mods are as follows, AEM CAI (MODIFIED INTO SHORT RAM), Hiboost FMIC, 3" no cat full exhaust from apexr1.com, and Unichip
Velocifero said:honestly you shouldnt need those injectors yet, but if you want to go higher then I would suggest them for sure, at this level you will just be dumping fuel. I am similar to Rob but no unichip, a couple extra goodies he doesnt have though.(enguard)
JDM Sam said:Replace all your vac lines. Then make sure there's nothing tapped off the line from the Purge Solenoid. Either you have a leak or they are running the wrong program on your Unichip. Did it run fine on the original map?
JDM Sam said:What are your mods and how much boost? Did your car run fine with no unichip installed? If so, it sounds like your unit/switch/harness was defective from the get go.
jmv said:a lil bit of old thread bumpage...
My wastegate appears to be bad. My vac reading is usually about 17, which doesn't seem as bad as most people, however i'm having the same idle and stalling issues described earlier, and when i blow into the line to my WGA, air goes through. When i pulled the entire vac line off, it holds air.
I'm still under 50K miles, so i'm trying to decide if i should try to take advantage of my warranty (with some parts swap outs), or get this piece. I would be a little concerned about boosting too much, though, since i don't have EMS. Right now i get a spike to about 9, and hold at about 7.5-8. I don't really wanna go higher than that till i get some EMS....
anyone got some suggestions??
I'll wait for dirty south to chime in, he has dealt with this a couple times, I haven't, but I think you should be fine swapping out with the boost situation, since you are already boosting higher than stock I dont think you will see a large spike off this mod and you should still be under 10 psi.jmv said:a lil bit of old thread bumpage...
dirtysouth_msp said:Your WGA is bad, replace it.
