- MP5T / 944
What about the coolant additives...
Mine just arrived today via UPS. It is a really awesome looking piece of work!Brian MP5T said:AWR Makes a ******* sweet radiator!!
Heh, yeah. I know they do. The problem is that will only work with the ION fmic. All the other kits use the stock smic location to route the plumbing so there is no room for a larger/longer radiator. It's a pretty easy (but not cheap) issue to address if you use a kit that involves cutting and routing the plumbing elsewhere. But if the kit routes the plumbing through the smic stock location you really can't use an aftermarket radiator. Your p5 radiator would actually be sufficient for an msp running the ion kit. The interesting thing is that I don't get the feeling people even running the ion kit are upgrading the radiator. So it basically sounds like the car maintains at safe levels w/o the upgraded radiator but I just wanted to make sure I wasn't getting a false read from my impressions.Brian MP5T said:AWR Makes a ******* sweet radiator!!
You could go custom... I had to.Heathen23 said:Heh, yeah. I know they do. The problem is that will only work with the ION fmic....
CRDMS1 said:Mine just arrived today via UPS. It is a really awesome looking piece of work!
Peace...(hippy)
Which kit djtest?djtest said:I have a fmic and until I changed from my coolings "winter mix " it ran soooooooooooo damn hot. but not I am mostly water in a nice "summer mix " and it's right back to where it was in stock form !
Thanks Jack.iON Performance said:Heathen23 - upgrading your radiator to the full length one like the P5 will allow your car to run lower coolant temps. We generally recommend this for those who track their car (road racing etc). It would be also beneficial in heavy rush-hour type traffic. Running a different coolant mix, higher pressure rad cap, and Redline water wetter will help as well if you're on the stock MSP radiator.
You've summarized it well, I think.Heathen23 said:It basically sounds like the general consensus is it's not a major issue and there are a few preventitive measures that can be taken. But unless you are going to track the car (not strip but road race) it's not a major concern.
At stock boost or 1-2 PSI higher, I don't think an FMIC will buy you gobs of performance. It will flow better and have less pressure drop, so you will see a small increase in power.Heathen23 said:One last thing if anyone cares to respond. Is it worth it? A few people have mentioned to me that the performance difference is minor which suprised me since dynos seem to put most kits in the 20hp range. I realize it's designed to increase the consistancy of temps but considering it's generating relatively large numbers on a dyno is it really not noticeable?
No problem. I don't mind participating in threads that promote good dialogue and don't degenerate to name calling and finger pointingHeathen23 said:Thanks for the all the responses!
Using a bazooka to kill a seagull! That's ginourmous. Looks nice though. He needs to use some elbow grease (or in this case some chrome polish) to clean up those endtanks.FC3s Boy said:we have put a few fmic kits on cars here and never had a problem with overheating even on TBL's car with a HUGE FMIC-
Yeah, I definitely realize upped boost is where the fmic plays the biggest role for power but why the big dyno numbers? FMIC's aren't typical power plants in any car, simply a support/efficiency mod. Maybe Jack from ion or someone else might have some insight why most fmic's are dynoing in the range of 20hp on the MSP because to me, although a nice feature, doesn't seem intuitive.At stock boost or 1-2 PSI higher, I don't think an FMIC will buy you gobs of performance. It will flow better and have less pressure drop, so you will see a small increase in power.
That said, the higher you plan to boost, the more critical it becomes to have an upgraded intercooler. The corresponding power gains will be larger per PSI with an upgraded flow/cooling path.
Heathen23 said:Using a bazooka to kill a seagull! That's ginourmous. Looks nice though. He needs to use some elbow grease (or in this case some chrome polish) to clean up those endtanks.Heathen23 said:Yea this was a one off for a guy who wanted a big kit, the other kits will have a smaller IC core- chris @ spd
Yeah, I completely understand (as would anyone else) why over a number of runs a fmic has greater efficiency thus showing better hp numbers than the same car w/o a less efficient ic. But that would show a number that holds more consistant not an increasing or gain hp number.iON Performance said:Heathen23 - a well designed FMIC set-up will try to minimize any pressure drops. That being said, as your vehicle runs, heat increases. On the stock I/C set-up, both the pipes and end tanks are prone to boost leak. This is one of the factors as to why there are "gains" from doing the FMIC. The FMIC is designed to reduce power loss as temperature goes up (compared to the stock set-up), which is the reason why the harder the runs (and longer the runs) the larger the difference in power output pre/post FMIC install.
Another reason why there are some gains with a properly designed FMIC is that you have increased the "reserve" amount of air between the turbo and throttle body. (ie: larger volume).
