Protege5 FS-ZE Swap Crank No Start
WeebRacer
Mazda Protege5 2003 Hatchback
Hi guys I am new to the forums.
I have a question for you all and hope you guys might have the answer.
I have a 2003 Mazda Protege5 Hatchback and the original motor which is the FS-DE locked up because of an oil leak. So we swapped it out with a FS-ZE. From there we swapped out the harmonic balancer and air intake cam and starter. Now the issue is it wont start. The engine is turning good. But we did a little more research into it and it has no spark. So now we replaced the crankshaft sensor and cam sensor but still no spark. Do you guys know what the issue might be?
Check your connectors. I remember someone here on the forum had two connectors swapped and had crank no start. (I forget which two but you can plug them in wrong).
Probably the neutral switch and reverse switch. Any blown fuses? Did you swap the cam gears? I know you have to with the 626, may be alright with the ZE.
