nice!! How is it running? All original motor and tranny? How many timing belt changes? Good stuff
Runs like a top. Never has left me stranded. Starts up on the first try, except on the very odd occasion where it needs a second try. I'm guessing the fuel pressure regulator might be bleeding off some pressure if the car sits for many days (which does in the summer when I pull out the summer toy). She even starts up fine in -40C (same as -40F). Of course, I've used synthetic oil since break-in and currently use Mobil 1 0W40. No oil leaks whatsoever.
All original motor and manual transmission. Come to think of it, even the clutch is original. I've had a clutch & Fidanza flywheel sitting on the shelf for 2 years now, but no need to change it. I also have everything I need to run force induction (MSP GT2554RLS, MSP ECU, FMIC, piping, oil lines, coolant lines, oil cooler, etc), but no time to put it in.
I had the belt changed at the dealership at 96000 kms. I've done all the timing belt changes since myself.
At around 169,000kms, the water pump failed, so I changed the timing belt at that time. Since then, I changed the belt and pump (just to be safe, I've made it a maintenance item with timing belt changes) at 265,000kms.
Next one will be at 361,000 kms.
