Antoine
Administrator
AND there are plates to rig up ford C4 or GM turbo 400 transmissions to the 20B.....so if the cosmo box dies, he can go to something tough - or he could just put a liberty transmission on it and be done.....
Always going for the hardcore choice...(thumb)
The good news is there are proven options and the C4 & Turbo 400 are widely known for adaptability & durability...I'm sure there are a bunch of companies that can upgrade them even further...As for liberty transmission...Do you mean from this company www.libertysgears.com?
Speaking of trannys...I'm sure there are a decent amount of options from the "manual" world as well...If I ever decide to go that route. Plus...I'm sure there are some "homegrown" tranny upgrade options here in Japan...
Bottomline...If I get to an upgrade point where the stock tranny can't "hang" any longer...I would want a tranny that is comfortable for the street (just like the stocker) but capable of handing gobs of power.
Ps...Making this post reminded me of an online article I read about a custom Cosmo...From AutoSpeed.com that was actually co-written by David Morris (DMRH).
Here is an interesting excerpt related to trannys & rearends:
With a TurboSmart e-Boost set to deliver 14 psi and with pump fuel in the tank, Gary's Cosmo has topped 420hp at the wheels during tuning. That equates to nearly 550hp at the flywheel.
The standard transmission- a 'high torque' Jatco unit - was recognised as a weak link in the armoury, so it was treated to a comprehensive (ie expensive) revamp. The trans was fully rebuilt and 'tricked' by The Transmission Centre. An aftermarket transmission fluid cooler is also installed and, so far, the trans has performed without glitch. The same can be said of the standard 3.9:1 factory LSD.
* http://autospeed.com/cms/A_1984/article.html
So in other words the stock tranny is fine until you move way beyond the stock turbos and start pushing over 400whp which is inline with my estimates.
It's interesting to note that instead of swapping in a beefier tranny, they beefed up the stocker's internals and added a tranny cooler...Good to know that combo held up (at least at the time the article was written) and that the stock rearend seems to be fine with all that power. (2thumbs)
Thinking about it...I'd prefer to upgrade the stock tranny's internals before swapping in a "foreign" tranny...That way I could still retain that original look & feel of the factory unit.
