Progress bushing remplacement
Darkjocker
Mazda Protege 5
Is there a better replacement than Progress sway bar bushing ?
(22 mm)
Thank in advance !
(freak)
i reused my stock bushings....you mean where it attaches to the car? Or where it attaches to the endlinks?
yeah, i just swapped over my stock bushing into that
+1 I also used the u-brackets because they were serviceable. I just bent it in the same shape as the stock brackets..........now those bushing are grease-able but i recomment using white lithium grease......the same kind that comes with the set.
The ones that attache to the car on the "U" bracket, on the crossmember.
I see http://www.energysuspension.com/ but i'm lost, i need the part number
I installed Energy Suspension P/N 9.5158R today. It's the 7/8" Greasable Sway Bar Bushing Set. I modified the brackets a bit in order to make it fit. I used a vice to straighten the legs of the bracket a little. For one leg for each side, I completely straightened and rebent about a 1/4" closer to the end. The Energy Suspension bushings are quite a bit larger than the stockers, so using the stock bracket would require trimming the bushing
My endlinks are shot as well, so there's still a clunk.
