Prodrive PFF7's on MS3
speed3 britz
07 Mazdaspeed3, 93 B2600i 4x4
Im looking at a set of 18x8 +48 (about 20lbs I think) Prodrive PFF7 wheels for my MS3. Never seen a whole lot of them, more so popular among the Subies. I believe the hub bore is about 56mm and if I remember correctly ours are 67? Would i be able to fit these if I run a spacer behind them, like 5mm spacer? Someone help me out and give me some input on what you guys think.
I understand that, but can I run a spacer to get it past that shoulder on the hub, or is it worth milling it out larger?
I would personally stay away from the spacer. I'm sure there are other wheels similiar in design that would work better
