problem: dragging?
Status
Not open for further replies.
derrick1623
'Content Monkey'
Contributor
'07 Mazda3, True red
it sounds like something is dragging underneath my car, i looked underneath, but there is nothing touching the ground...i checked around the sway bars, and stuff but i have no idea what it is!
i thought maybe a cv boot, but they are intact
also, if i reverse...it knocks when i stop...i dont know how to explain it...it JUST started just now...help!
It could be your endlinks or something along those lines rubbing on your rims or tires maybe...??
Check the inside of your rims to see if the rims and or tires are scratched.
Also, try having someone drive behind you at night to see if whatever is "dragging" creates sparks.
Its the end of the world. Everyones cars are screwing up. gah i still dont know whats up with mine. Good Luck!!
have you been using your ebrake to use turns? i know if u loosen it up sometimes that can drag too but that will actually spark when u drive. -=)
- John
i only played with the ebrake like 3 times, in the snow...i figure it is either my rotor...or i ****** up something.
Status
