Prius Shuts Down in the Snow
  • Thread starter Thread starter 16902
  • Start date Start date
1
16902
I found this to be somewhat scary:
Prius Shuts Down in the Snow, Reader Complains
Toyota Calls Automatic Power Reduction a Safety Feature
By Joe Benton
ConsumerAffairs.Com
January 26, 2007<!-- date -->
The Toyota Prius is known to occasionally shut down its hybrid engine system for no apparent reason, wear tires quickly and unevenly, even drain a battery dry when parked for an extended period.
But here's one of the oddest Prius stories on file at ConsumerAffairs.Com:
"When my car is on any kind of slick surface that causes one of the front wheels to slip, ALL power to the drive system is stopped," wrote Christopher of Reston, Virginia.
Christopher said he first experienced the problem with his Prius "on a sloped gravel driveway in July but discounted it as a temporary thing."
Then the snow fell.
"This past weekend I was on a snow-covered road with about an 8- to 10-degree grade. Driving at 20 miles per hour, one tire began to slip on the snow and the car came to a stop. The wheels then refused to engage, because one would slip a little, regardless of throttle position," he wrote.
Christopher tells ConsumerAffairs.Com that he "had cable style tire chains and installed them properly on the front wheels and tried again. Still, a tire would slip on the 4 or 5 inches between the cables and the car would refuse to move."
Ultimately, he said, the only way to get the car up the remainder of the hill was to get out and push while his son put a foot gently on the throttle.
His Toyota service manager told Christopher that he was able to duplicate the symptoms on a level snow covered surface and apparently achieved the same results with two other Prius cars that were in the dealership fleet.
But after reporting the problem to Toyota, the service manager told Christopher that the Prius was operating as designed.
Christopher said that he "will consider this vehicle unsafe for road use under any snow or ice conditions and frankly feel that if all Prius vehicles are designed to do this someone ought to look into the situation to try to force Toyota to modify the design."
Not a Safety Problem
Toyota spokesman Bill Kwon agrees that the traction control systems in the Prius could impact performance in snow conditions but says that is not a safety problem.
"Prius has TRAC (traction control) as standard equipment," he said. "The purpose of traction control is to helps prevent wheel spin and minimize slippage of the drive wheels by applying brakes and/or reducing engine power."
Kwon points out that an 8 to 10 degree grade "is a fairly steep grade and combined with snow would cause a loss of traction which will activate the traction control system and therefore reduce or cut power."
"A vehicle without TRAC in those conditions," Kwon adds. "would probably just start spinning in place and eventually spin out of control. In my opinion, it's better to have the vehicle stop then to have the wheels spinning and out of control."
not good at all! I see quite few priuses around Rochester, they seem to be handling the snow though?
Yikes. Funny thing is his statement sounds logical out of context. But on a 10 degree grade, that's ridiculous. That would mean you can't go up any hill at all... And IMO it's a safety issue because you're now standing still and if something happens and you need to pull over, you can't even do that.
you mean yuppies, hippies smoke pot and are mostly poor, yuppies on the other hand are relatively well off and are so smug that they smell their own fart thinking it smells of roses
Yuppies are what in there mid 50s to mid 60s now? I actually know afew rich hippies.
Eeeewww, they do take showers though, right? The girls shave?
Anyhow, I just wonder if this "traction control" is on other Toyota hybrids. My sister just got a Camry hybrid last month and we haven't had any significant snow yet.
Newf said:
you can't turn off the traction control?
I'm pretty sure with Toyota, their systems allow you to "turn them off" which really means it just raises the point at which they will engage.
I do not know if they take showers. They do smell funny.
If the Camry Hybrid has TCS it will either have a on/off button or a light of the gauge cluster.
