No the wastegate is not water-cooled. It's just a Turbosmart 38mm EWG. The two nipples are for boost/vacuum.
Downpipe is 2" stainless mandrel bend but the closest part of the turbo outlet is progressively going from 1" (wich is turbo exducer diameter) to 2".
EWG dump pipe is 1" stainless mandrel bend and dumps right where you see it stops. There are stainless brackets between downpipe and dump pipe so they will be more solid and less affected by engine vibrations. Also added a little stainless bracket on the downpipe to bolt it under the bell housing where the OEM exhaust holds.
Just waiting for my 2"-3" stainless cone adapter, 3" stainless flex pipe with inner interlock and 3"  stainless V-band flanges to finish the downpipe.
Only after finishing it I'll be able to wrap all this with DEI titanium wrap.
