???PG turbo minifold???
meha11
ms3
What happened to the PG manifold? i havent heard anything of it since the GB thread. From what i remember, people should have had these installed for at least the last 2 weeks. Anyone got any reviews to share?
theyre not installed yet.
they just arrived in california, I believe it was cali anyway. Then they get mailed to ken, then they get mailed to everybody who bought them.
ok thanks, i am looking forward to public opinion, mainly i am curious as the noise increase but i was also wondering if it could possibly cure a smoking turbo.
As i understand it, some turbo seals leak slightly due to reduced back pressure, so maybe by adding the less restrictive manifold, it will equalize and solve the issue. just a thought.
turbo's naturally create back pressure @ the turbo. using a less restrictive manifold youre only increasing exhaust flow and thus making the turbo work more....so no it wont cure a smoking turbo, if your turbo is already smoking it will only make your problem worse.
a manifold will in no way do anything for a smoking turbo. you most likely dont even have a smoking turbo. it is most likely PCV blow by. get yourself an oil catch can, and call it a day.
i have no smoke, i was just wondering.
Cheers
