Peformance or looks?
What to do with my moola?
  • Peformance upgrade of some sort
    Votes: 67 87.0%
  • Interior or exterior customize
    Votes: 8 10.4%
  • Something different?
    Votes: 2 2.6%
  • Total voters
    77
Intakes dont hold boost. A diffrent BPV or boost controller will.
I think your right. When I was switching my dual port bov from 50/50 to full recirculated, I decided to put the stock one back on just for the hell of it and car ran great. All I could here was the SRI. Then I reinstall turbosmart and the suction noise from the SRI got way louder very noticeable. I think this shows that turbosmart does holds boost better than the stock bpv. This is something you guys with stock bpvs do to see if your bpv is leaking. Of course if you can get an aftermarket bov/bpv to try it with. Thoughts?
Oh yeah I forget to mention that I also have an PG Turbo Inlet installed, but I don't think that matters since I did not toucht it while doing this experiment lol.
When running the stock BPV, my max boost, as displayed on the Dashhawk, was in the neighborhood of 13.3-13.6 psi. By simply installing a Forge BPV, max boost jumped to over 16 psi, and I regularly see mid to high 15's.
So, yes, it makes perfect sense that you'd hear more intake noise with an aftermarket BPV, since the turbo will be sucking so much harder. (nana)
Where on the DH do you monitor for max boost. Is it "vac/boost"? If so then at steady speed I see 16.xx. To the OP get an after market bov/bpv and join the 16psi club lol.
Yes vac/boost is where you will see your boost pressure and also the vacuum your motor is running.
i think the PG full length would be the way to go though. your getting the most power from that mod then almost any other mod.
