pedal assembly
Status
Not open for further replies.
akinat90
2000 mazda R4
Loking for a manual pedal assembly or a brake and clutch assembly for a 2000 on protege.
Doing an auto to manual conversion
I've got a full pedal assembly from a speed. Never shipped to barbados though. I'll take a pic and post it up. Everything's in pretty good condition.
Do you need the brake master cylinder as well, or does yours have a port on the side to feed the clutch?
Here's a couple pics. I can sell you the booster too if that's needed. Not sure if the auto and manual use the same booster. It could differ slightly because of the MSP pedal setup. In the second pic you can see the brake master cylinder on the right with the hose coming out of the side. That goes to the fitting on the left side of the clutch cylinder on the firewall. Also if you noticed in the pics, it'll include all of the fastners. Standard nuts for the clutch and brake assy, but special sized bolts for the gas pedal.
Status
