P0302 with 26,720 miles
rzc
2019 CX5 Signature, Snowflake White Pearl
2023 CX30 Select, Jet Black
The CEL just came ON. Autozone says it's a P0302. This seems early for my 2019 CX-5 Signature. I searched this site and the web, is there a TSB for a misfire issue?
I'm planning to diagnose further this weekend to see if it's the coilpack or sparkplug.... again, regardless, seems early.
Anyone else experience this same problem?
So this morning the CEL is OFF. I didn't reset it so hopefully it's just something loose who knows.
With your low mileage, is the driving environment mostly local surface streets and short trips?
Still shouldn't
Knowing the mileage would be helpful.
Do that if it comes back.
Yes, but it was due to defective spark plugs. with over 300,000KM on the engine. All the original ignition coils still work well.
It's in the subject line ... P0302 with 26,720 miles
Still shouldn't
My thought process on this is with a life of short trips on surface streets, the skyactiv 2.5T in the OP's signature trim cx5 is spending much more time at an enriched "warm up" mixture than a car driven typically longer distances at a time and highway use. Additionally, with lower speeds on surface streets, that lower 26720mi on the odometer could be equivalent engine time running of a typical CX5 at double the mileage. If I recall, the turbo engine is recommended to have spark plugs replaced at 40k miles?
So, to me, (IMHO) it stands to reason that a vehicle driven in such an environment as I had asked about could be ready for some new spark plugs. It's possible that the motor could possibly have some carbon buildup issues from that type of operating environment.
@Lazy2.5 , what's the reasoning for your position of "still shouldn't" ?
If it were my car, I'd wait to see if the code came back. If so, I would give it an "Italian tuneup" with a nice couple of hours drive in the country with some heavy throttle and higher rpms. If that didn't help I'd go new spark plugs. That would be my progression before going to a mechanic or dealer.
I missed it.
It's true, but how often do you see CX-5's with misfire codes on this site? When you do, they are usually at over 100k miles. At 26 miles, assuming it's not some temporary glitch that goes away, it is unusual regardless of the way it's been driven.
I do have the NA 2.5. Spark plugs have always been changed at or before the suggested interval. As I have mentioned before, the only time I ever got a misfire code was due to defective (almost new) spark plugs. My car saw lots of city driving when it was newer.
Yes, do that, OP.
For optimal engine and catalytic converter health, a solid 30-minute drive at highway speeds (e.g., 50-60 MPH in 6th gear) with a light throttle is highly recommended, ideally once a week or more. This duration is sufficient to ensure the engine oil reaches its optimal operating temperature, effectively burning off contaminants and excess fuel that may have accumulated in the crankcase, and allowing the PCV system to function at its peak. This sustained, moderate operation also keeps the catalytic converter within its optimal temperature range (400-650°C), efficiently oxidizing accumulated carbon deposits on its surface.
Driving for "a couple of hours" solely for the sake of an 'Italian tune-up' is unnecessary and makes no sense, as the primary benefits are achieved much quicker.
During my vehicle's tuning process, datalogs revealed that the stock Air-Fuel Ratios (AFRs) would drop to a very rich 10.5-11:1 during sustained Wide Open Throttle (WOT). Even after tuning, the target value of 12.5:1 AFR is still rich compared to stoichiometric. This rich mixture, commanded by the ECU to cool and protect the engine and catalytic converter under extreme load, will not burn off deposits. Instead, the combustion of excess fuel in the exhaust manifold and converter will lead to dangerously high catalytic converter temperatures.
Therefore, for truly removing engine and catalytic converter deposits, the best way is through regular, sustained driving that brings the engine and exhaust components to their optimal operating temperatures for at least 20-30 minutes.
I want to clarify: If attempting the 'Italian tune-up' through more aggressive means, it should be limited to 1-2 consecutive acceleration runs, not exceeding 5000 RPM, and in a gear no higher than 3rd. Pushing beyond these parameters, such as higher RPMs or in higher gears for sustained WOT, triggers very rich AFRs (Especially in your turbocharged engine) to protect the engine and catalytic converter from extreme heat. This richness, while protective for the engine, makes the process totally redundant for burning off deposits in the catalytic converter, and paradoxically, contributes to additional deposits as well as obscene cat converter temperatures. (over 900c observed while logging data with Mazdaedit)
The focus should be on consistent, moderate-load driving to maintain engine and emissions system health, rather than relying on extreme, short-duration events that induce damaging heat.
...and a bottle of Techron
Had a CEL for a few weeks, myself. Vehicle is a 2016.5 CX-5 GT AWD with north of 125K miles, plenty of urban stop-and-go driving in the mix, and occasional highway and longer trips. Hadn't been "exercising" the car much.
Basically -- did a couple of GDI intake valve cleaning treatments, a bottle of Chevron Techron in a couple of tanks of gas, along with swapping out the original ignition coils and the spark plugs. CEL went off today. Idling is smooth, again, and low-end performance is back. In the case of my vehicle, apparently driving "like a granny" with a high percentage of city driving is causing gumming-up of the works. More-frequent use of Techron, highway driving at least several times weekly, annual GDI intake valve cleaning, and instances of "Italian tune-ups" ought to help keep it healthy. (Have done that with prior vehicles for decades, but on this one I had gotten lazy. My bad, as the kids say.)
Agreed. I'm probably due to run some more fuel system cleaner soon. That's when it is particularly useful to do some harder acceleration - let the mixture run through the injectors more freely.
I aim to go WOT about twice a month. I go based on how stinky my exhaust is when I do it. There's no noticeable stink in the cabin if I do it any more often than that. After seeing how hot my cat converter got, I am now limiting throttle position slightly and shifting at around 5000rpm, but in two different gears (etc. 2,3) instead of just one clean pull to 5500-6000rpm.
I find this is the best approach, because I am mostly below 2000rpm otherwise.
Thank you all for your suggestions.... once I have day off, I will look into it more.
Just for a quick test, I disconnected the connector to each coil pack one at a time. I noticed that when I got to #2, the idle was not much difference from when I did #1, 3 or 4. Now I wonder if it a spark plug issue on #2.
It was getting late so when I have more time, I will remove the spark plug and inspect that.
More to follow, this weekend I hope.
Update.....
All good now.
I had an outstanding experience at #DeMontrondMazda. The professionalism, customer service, and follow-up were all excellent.
I brought my CX-5 in for service (TSB 01-001/23) and was very impressed with how smoothly everything was handled. A special thank you to AK for your guidance and assistance, and to Austin and Dylan for ensuring the work was completed both efficiently and thoroughly.
It’s clear this dealership values their customers, and I truly appreciate the level of care shown. I would highly recommend #DeMontrondMazda to anyone in Houston looking for reliable and professional service. Ask for Dylan!
Update.....
All good now.
Less than ideal dealer experience for me..
