doctormike
What's the Optima battery that fit's the P5? What model? Does it bolt right in? (under the strut brace that is)
wipedawg said:red top and yellow top are about the same size... and unless you are running tons of lights and a huge system, i'd go with the redtop.
I have a Kenwood 1000 watt amp with two Audiobahn subs hooked up to yellow top and I have serious light dimming.BLKFIN said:I had over 2000 watts of "old school" Precision Power amps and with the factory battery the head lights would "dim" so much it look like the lights almost turned off!!! With the Optima I saw absolutely no "dimming " of the lights.
bradicus18 said:I really believe that our alternators suck. Does anyone else agree? Could this really be a prob for some people? My lights dim when my cooling fan kicks on. (notcool) Has anyone replaced theirs with a higher capacity and seen improvements? I will probably be buying a Red Top since I will not be going full out on the audio (probably just two amps total with not alot of power). But, I would like to believe a new alternator would work wonders.
shaneMazda2000P said:replace ur battery to chassis wires to bigger ones and replace the altenator to battery with a thicker wire too, u would be suprised the differance , with the system i had, stock i would dim my lights almost off, with those modifications they wouldnt dim at all..
