oil temp gauge?
2001 Mazda Protege MP3
I have an oil temp gauge but dont know how to install it. Anybody on here know? I would really appreciate. Also if you know how to do fuel pressure that would help too
Yup, I run 2 of these gauges off of it. Some will tell you that the readings aren't perfect, but they should give you a much better idea of what is going on in your engine then what your car tells you, and is a simpler install then the "perfect" way. (Coolant temp, oil temp, oil pressure)
Cool thanks. Anyone know about the fuel pressure then?
In cabin, or in the engine bay? They are both pretty straight forward. Most gauges come as a "kit" and supply the necessary fitting to "splice" into your cars fuel supply line. Just find where the hose is located in the engine bay, and follow the manufactures guidelines from there. Cut, splice, sending unit (electric most of the time), gauge, unless your doing one in the engine bay. Then it just stays put.
Sorry if my info sounds pretty dry cut, but it really is a straight forward job, you'll do fine :) Oh, Teflon coating is your FRIEND on this one :D
Taken from a site i found most useful when i had my FD...
http://robrobinette.com/fuelp_gauge.htm
These are all engine bay gauges though...but still, practically the same, lol.
Start here...
http://prosportgauges.com/amber-white-premium-fuel-pressure-gauge.aspx
Then Here...
http://summitracing.com/parts/SUM-G1710/?image=large
or bling it up with this one, clamps included!!!...
http://summitracing.com/parts/MRG-2975/?image=large
Then put it all together and presto! Make sure you have some GOOD hose clamps as well, you don't want that to leak at ALL!
PS. Somebody please confirm the hose diameter size? Want to make sure I'm linking the right parts for the guy :D
