Oil leak into Plug Well No. 4
wamb123
Oil leak into Plug Well No. 4. Has anyone had this problem? I changed the valve cover gasket and it didn't help. Oil is leaking in and causing the plug/wire connection to short.
You don't have good enough of a seal. You need to redo your valve cover gasket and make sure to use rtv at the corners.
