oil cooler
before the oil filter. It sits on the oil filter. I don't see how it works to cool anything sitting ON the block.
yep, it has a coolant line through it. works very well considering where it's located, my pressure as well as temp have both stabilized because of it
I have the extended screw if you want to do it. All you would need is the cooler itself and the fittings.
can you post me a picture?
