J JasonBourne Member : 2003 Mazdaspeed Protege Apr 21, 2008 #1 i just want to know if the MSP have a oil cooler? Thanks (thinkbeer(huh)
A avarela86 Member : Honda S2000 Apr 22, 2008 #4 before the oil filter. It sits on the oil filter. I don't see how it works to cool anything sitting ON the block.
4 4orcefed Member : 2003.5 mazdaspeed Apr 22, 2008 #6 I think there is a coolant line that runs through it.
J JCell BEETEK! : 2014 Genesis Coupe R-Spec Apr 22, 2008 #7 yep, it has a coolant line through it. works very well considering where it's located, my pressure as well as temp have both stabilized because of it
A avarela86 Member : Honda S2000 Apr 22, 2008 #8 I have the extended screw if you want to do it. All you would need is the cooler itself and the fittings.
O orlandomsp F - L - O - R - I - D - A : 03.5 MSP Apr 22, 2008 #9 JasonBourne said: can you post me a picture? Click to expand...
