Selling almost complete stock turbo kit
-OEM GT2554r turbo w/ factory exhaust heat shield
-Adjustable Wastegate with factory heat shield
-OEM callaway manifold w/heat shield
-OEM downpipe ported to match gasket w/ j pipe and heat shields
-Oil cooler w/ hoses
-turbo water lines, fittings, and water supply hose
-oil feed, oil line, oil return tube for turbo w/ o ring and head shield
-Radiator w/ both fans, rad mounts, and hose
-Smic, cold pipe, hot pipe, bpv, bpv hoses
-intake pipe and box
-ECU
Things the kit doesnt not include
Main bearing plate
Longer stud for oil cooler
Air filter
Gaskets
Lmk if there is something missing Im asking $730 shipped obo. I can provide detailed info. I will provide the mileage for the kit
-ECU
Main bearing plate
Air filter
Gaskets
