Obx header question?
PRO5.REL
MAZDA PROTEGE5
alright im gonna buy a used obx header but it has no gasket with it..guy said i could buy it at autozone.
will it fit with aftermarket headers?
Yes
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
You can order one from onlinemazdaparts.com as well. Get the donut gasket (header to midpipe) as well...yours might not be reusable.
Truth. I had to use a Dremel cutting wheel to get my old on off. A new one is around $6... make sure they don't give you a generic round gasket. The one you need has a bit of a cone shape to it.
i have a same problem with him..
i search it on onlinemazdaparts.com but i couldnt find where is it.
can you guys copy it and paste it in here.?
tnx guys,,
another option if you want it fast is go to a mazda dealership, they should have on in stock but itll cost a bit more than someplace else
The manifold gasket or the donut gasket? If you go to AutoZone or Advance Auto Parts, they should be able to pull up a diagram of the exhaust and you can point out which one you need. Its the gasket directly in front of the mid-pipe which has the 2nd cat.
Sorry for the late late reply....
I needed the gasket from the block to the header...got it autozone for like 15.00
Now I'm having a hell of a hard time taking out the sensors any tips guys?
It feeel soo hard to take off
O2 sensors? Sometimes they can be a b**** to get out. Try a little heat from a torch. Do NOT use wd-40 or pb blaster... you will ruin your sensors. Just keep turning it back and forth until it breaks completely loose.
will a heat gun work?
and can i use something on that one part on the side of the header the screws on?
do you have the tool for it...it makes it alot easier you can do it w/o it but i recommend it...mine came off with a little help from my friendly neighborhood breaker bar (piece of pipe i had lying around)
well i just bought the tool for it..im gonna give it a try in a bit...
theres also another hard part to take off and its the piece thats connected to a pipe on the side of the old header idk what its called but what can i use to make it loose besides wd40
noegrut1
That one?
yea the EGR pipe....well i got that bad boy in..thanks for all the help guys! ill post pics but its nothing to show off about but ill post it asap
