What specific OBD2 values do you find most valuable, in the tracking down of a P0300 Random Misfire Detected condition?
Suggestions on which combinations of OBD2 scanner indicators to focus on?
Hopefully, some who have solid experience using the OBD2 to identify sensor outputs and conditions will offer some guidance.
Will be configuring an OBD2 scanner, soon, to attempt to identify the cause(s) of this occasional condition on my vehicle. (It's a 2016.5 CX5 GT AWD with almost 130Kmi on the clock, with fairly good maintenance.) Hasn't been specific to a cylinder, just the generic P0300:00 code. And it hasn't occurred recently, within the last few weeks.
Recent maintenance/changes (post-P0300 CEL displayed): new spark plugs; new ignition coils.
According to some troubleshooting guides I have seen (not Mazda vehicle specific), the possible causes of the P0300:00 condition could include:
Initially, it looks as though the following are a good place to start, in this UltraGauge MX scanner:
Page 1 settings:
Page 2 settings:
- Spark plug malfunction -- have swapped-in new spark plugs
- Ignition coil malfunction -- have swapped-in new ignition coils
- Ignition coil related wiring harness or connector malfunction
- Ignition system -- improper operation
- Fuel injector malfunction --
- Fuel injector(s) -- improper operation --
- Fuel injector related wiring harness malfunction
- Erratic signal to PCM
- CKP sensor signal malfunction (crankshaft position sensor) --
- ECT sensor No.1 signal malfunction (engine coolant temp) --
- MAF sensor signal malfunction (mass air flow) --
- MAP sensor signal malfunction (manifold absolute pressure) --
- IAT sensor No.1 signal malfunction (intake air temp) --
- APP sensor signal malfunction (accelerator pedal position) --
- TP sensor signal malfunction (throttle position) --
- VSS signal malfunction (vehicle speed sensor) --
- Related connector or terminals malfunction
- Related wiring harness malfunction
- Poor drive belt assembly or adhesion of oil -- 35Kmi since last swap; haven't seen/felt anything on belts
- Drive belt auto tensioner malfunction -- has 35Kmi since last swap; haven't heard any strange noises out of the thing
- Air leakage from intake air system (between intake manifold and cylinder head) -- air intake from airbox through the throttle body seems to have good connections, hose condition, and no apparent leaks; throttle body itself has a new gasket
- Engine malfunction
- Insufficient engine compression -- haven't done recent compression and leak-down tests
- Engine coolant leakage to combustion chamber -- coolant level remains consistent
- PCM malfunction
Page 1 settings:
- RPM
- MPH
- ECT - engine coolant temp
- MAF Sensor 1 g/s
- MAF Sensor 2 g/s (calculated)
- MAP (intake manifold absolute pressure) PSI
- IAT (intake air temp) ºF
- ECM battery voltage
Page 2 settings:
- APP 1 (accelerator pedal position 1) %
- APP 2 (accelerator pedal position 2) %
- Throttle Position % CMD
- Throttle Position 2 % absolute
- Absolute Throttle Position 1 %
- Relative Throttle Position %
- Vehicle Speed MPH
- Can use additional outputs/conditions if they can assist in nailing-down "random misfire" conditions.
